Grinding feeling on floorboard
In the last week or so, I have noticed a strange grinding feeling coming from the floorboard on both sides. It is more apparent on the passenger side. I thought it could be my tires, but that "knobby" feeling seems a little different. It is not anything to do w/ brakes. I feel this grinding all the time, not just when braking. It feels like a "rolling grinding" if yall can picture that. I don't know too much about the front end assembley and was wondering what it might be. I've greased all my zerks not too long ago. Can it be some kind of bearing or something in that nature. Thanks for the help.
I've got the same thing! I'd be interested to find out. I was thinking wheel bearings too, but I bought the truck from the dealer, who replaced brakes at all four corners before the sale ... I guess that doesn't mean much.
Guest
Posts: n/a
I had a brake pad liner come off on mine. Did exactly like you a describing at all times, initially I thought it was a bearing. Was worse when braking however. It was the inside pad so I couldn't easly see it when I stopped on the side of the road. When I got home I saw the rotor filings on the tire that gave it away.
grind
check your left front whee bearing,,, on mine, the nut backed off due to wheel rotation. i caught it in time & no damage was done. the grinding noise was the brakes on that side----
my truck there is no cotter key on the nut, they used a nylon lock nut
2 wheel drives use that nut
I haven't had time off of work to get a look at it yet. Hopefully tomorrow I can jack up the front end and spin the wheels to see if I can see or feel anything outta the ordinary. I'm also gonna check the pads and see how they are wearing. The pads don't have more than 6k on them. Whatever it is, I hope that it is cheap, being a broke college kid and all.
Check the feont wheels for play. Jack it up and try to move the tire from top to bottom. Also check the u-joints for play. You don't want to have a wheel bearing go out on the road. It happened to me a 70MPH. Not fun! Good luck. Hope this helps.
Eric
Eric
mstep3
05-20-2011 12:07 AM
Mega07
07-19-2007 12:37 PM
2k1yzfr1
13
12-03-2004 09:43 PM
cLAYH
02-06-2004 10:59 AM
