Gray smoke
Old 09-16-2003, 10:45 AM
BigBlue's Avatar
Re:Gray smoke
What's your FP?
Old 09-16-2003, 10:58 PM
DarrellB's Avatar
Re:Gray smoke
[quote author=Incanus link=board=4;threadid=19724;start=0#msg185257 date=1063713893]
Day before yesterday, the truck ran great. Yesterday, it seemed sluggish, and didn't do as much when the turbo spooled. When the pedal was put down, the smoke was not black, but a sort of lighter gray.
Not white smoke, not blue smoke, and not brown smoke. Oil looks good, no antifreeze glop.
But it starts great, idles smoothly, doesn't miss, and gets over 20 mpg.
Fuel suddenly gone bad? Dribbling injector? If it was a head gasket, wouldn't it be blowing white smoke all the time, especially at start up?
It's an '02 ETH/DEE, with Comp (no pump wire), 275's.
Thanks. I.
[/quote]
This kinda sounds like what my truck is doing now. Does yours feel like it cuts in and out under hard acceleration? Mine just started cutting out today, and I noticed in the rear view mirror that when it did I got a little gray smoke in with the black. : I've been told it's the VP-44 heading down hill but have yet to have some one pull the codes for me.
It almost feels as if I took out the DD3 and put the stocker's back in.
DB
Old 09-16-2003, 11:01 PM
StakeMan's Avatar
Re:Gray smoke
Check your MAPP sensor.
Old 09-16-2003, 11:16 PM
DarrellB's Avatar
Re:Gray smoke
My map/boost sensor is fine so is all other electrical conections.
My truck started being slugish just when it was cold then once it came up to operating temperature and I shut it back down and then restarted it it would run fine. Now the problem is all over the place sometimes it will run good others it will run like I put the stock injectors back in. ???
Hopefully tomorrow I will know more. A friend is coming over with his scan tool to give me a hand.
DB
Old 09-16-2003, 11:33 PM
StakeMan's Avatar
Re:Gray smoke
I would guess, MAPP, IAT, or the VP. I hope its not the pump. Mine does that every now and again.
Old 09-16-2003, 11:49 PM
DarrellB's Avatar
Re:Gray smoke
[quote author=StakeMan link=board=4;threadid=19724;start=0#msg185745 date=1063773237]
[/quote]
You and me both.
DB
Old 09-17-2003, 08:27 AM
BarryG's Avatar
Re:Gray smoke
Grey smoke can equal unburnt fuel, not from the normal combustion process (ie black smoke due to more fuel than the alloted air can burn) but from improper timing of the injection event so that fuel doesn't even ignite or ignite as much as it should due to too late or too early of an injection event (injection pump timing failure). Mine belched all kinds of grey/blue smoke when my vp said seeeeya.
Old 09-17-2003, 10:28 AM
moneyman's Avatar
Re:Gray smoke
mine did the same thing. I took of my comp box and it ran fine for stock. Sent it back to edge they gave me a new box and now everything is perfect
Old 09-17-2003, 12:05 PM
BigBlue's Avatar
Re:Gray smoke
I'd take the comp off and see what that does. If that solves the problem, then I'd contact Edge and have them ship you a new one.
Old 09-17-2003, 10:35 PM
DarrellB's Avatar
Re:Gray smoke
My problem is solved. 8)
Stakeman was almost right. It was the map/boost sensor but what was wrong was I put a new sensor in about 2 weeks ago thinking that was the problem but didn't clear the over boost code in the ECM. Scott came over this evening with his scan tool and cleared the code for me and all is good.
Thanks again Scott for all the help.
DB
Old 09-17-2003, 10:43 PM
StakeMan's Avatar
Re:Gray smoke
MAP and IAT sensors play a very important role in fuel and timing.
Old 09-18-2003, 12:18 AM
DarrellB's Avatar
Re:Gray smoke
Yep, that's why I'm buying a scan tool. :
DB
Quick Reply: Gray smoke
