Got towed home today.....She died!
Pulling away from the toll booth and the truck just quit running.
When i pulled over ( not to easy with engine not running) i turned off key and back on everything seems to cycle the correct way but it wont start.
Cranks fine ........My fuel pressure is fine.
Is there anything i can do myself so i dont get beatup to much when i bring it somewhere...
Check engine light stays on continuesly........
Gonna call a place here in NJ called........ Extreme Diesel Performance hopefully have towed there....
Gotta ask the obvious.
Are you sure you have plenty of fuel in the tank?
Since you have a check engine light, it's most likely something else though.
Your '99 needs to be hooked to a scanner to pull the codes.
Performance Diesel place may or may not have a scanner.
Hopefully turns out to be something cheap and simple like a crank/cam sensor.
phox
phox
Yea plenty-o-fuel..........
I also replaced the crank position sensor already about a mth ago....
It threw the light on that and the dealer i bought it from scanned it and was supposed to fix but i didnt have time to wait so did it myself....
Cheap would be good since i just paid 120.00 for the tow....
rockwind
21
05-18-2010 05:44 AM
Beast2B
12-08-2009 01:44 PM
Box5
07-19-2007 06:46 PM
