Glow Plugs
Old 05-07-2003, 10:30 AM
BigBlue's Avatar
Re:Glow Plugs
Thanks man. If I was pushing enough boost, I may do it. But I'm not. Hey, did you port and polish it out? Might gain you some extra air flow.
Old 05-14-2003, 02:19 PM
HOHN's Avatar
Re:Glow Plugs
As others said, no glow plugs on CTD.<br><br>The heaters are there mostly to reduce emissions in regular usage until the engine is up to temp. They aren't needed for starting in moderate temps or higher (over 50°F or so).<br><br>They are only needed for starting in very cold weather. After that, the run to reduce smoke and emissions, not necessarily because the engine needs them.<br><br>They also draw a LOT of current-- like 90 amps! That's why your headlights flicker when they cycle.<br><br>Now that it's warm, I crank mine instantly and start it like a gasser.<br><br>HOHN
serious
03-08-2006 08:08 PM
Hillbilly_Deluxe
09-24-2005 03:38 PM
jlasich
02-09-2004 06:13 PM
TheMoose
11-13-2003 03:32 PM
FastSS
12-22-2002 01:48 AM
Quick Reply: Glow Plugs
