gear indicator problem
Need to know how to fix this problem, When I put my truck into park the indicator moves back slowly even after it is in park. Does something need to be adjusted or ???? Please help, Thank you.
There is an adjustment under the dash. If memory serves me correct, look for a black cable by the steering column. It has a little plastic housing with a small wheel (kind of like a clock). The wheel is the adjustment for the indicator.
There is also a plastic piece that is on the transmission, where the linkage is, that wears and will alo cause the indicator to be off. It will also throw off the gear position indicator by a 1/2 position, or more.
boomerang
12-11-2007 07:56 PM
MX429
11-29-2007 02:23 PM
tslewisz
01-24-2006 05:08 PM
