gauge help for a noobie
I've been reading the past few months and looking at pictures, but still am unsure what gauge setup to go with. My truck is stock, and I don't have plans to bomb it (famous last words)
Being a manual, I don't need a tranny temp. I plan on filling a triple gauge pod with EGT, Boost, and Fuel Pressure.
A-pillar or Dash mount?
I've looked at tons of pics; it seems most people go with the A-pillar. Do you really lose any visibility? Is any installation easier than the other. I'm thinking the dash mount would be a good place since that space is un-used, and it wouldnt block any visibility.
ISSpro vs. DiPricol?
Fuel pressure; 0-30 psi, is that high enough?
Turbo Boost; how high does it get; 60psi sounds a little high, and maybe 30 too low. I found a 35psi Dipricol.
Thanks for any input for this noob
RenegadeT,
The A pillar is probably the easiest to install, it will block a little vision but for most folks you won't notice it after a couple of hundred miles etc. We have been selling a lot of the above the rear view mirror mounts on the windshield, a little more effort to install but excellent visibility and totally out of the way otherwise etc.
We a fan of the DiPricol's as well as Auto Meter gauges, take a look at our site and you can see pics of them all to see which "looks" right for you and your truck. We also have a real nice installation wiring harness that makes installing gauges real easy as it includes all the little stuff first timers usually make three trips to the hardware store to get etc. Give us a call if you have any questions etc.
Mark @ DPPI
Mark @ DPPI
Guest
Posts: n/a
Just Installed the ISSPRO guages on the A Piller. Did the complete install in about 4 hours. 6 hours if you add up the time it took to find the leak in the Fuel pressure connection. Glad I used an isolator. Being manual I went with Pyro, EGT, and Fuel Pressure. I was glad to see 16 psi at idle 14 at WOT.
I am very happy with the setup. Good night visability as well as day. Guages match pretty well. The only think I will be doing is coating the bulbs to give it the greenish glow like my dash.
0-30 psi Fuel
0-40 Boost
Scott
Better update my profile. Got Wife approval on guages.
0-30 psi Fuel
0-40 Boost
Scott
I have the same setup as Sgregory. I even painted the bulbs green. Looks great.
Unfortunately, my FP gauge read 0, so I'll be installing a LP this weekend.
Note: I found that with the A-pillar mount attached to the stock A-pillar, the assembly will not go into place without breaking off the retainer on the bottom.
I recommend you get moving on ATLEAST the FP gauge. Your truck will run pretty decent with 0 FP, but ain't good for the IP.
Good luck..........
Good luck..........
I'm still hunting too....but have heard nothing but good about Isspro.
Mark's site kinda gave me an idea. Isspro (rainbow) on the column. Over mirror mount for boost and fuel. Isspro does have a 40 psi (manifold pressure) gauge. I also like the dakota digital fuel pressure gauge. ordinarily I'm not much for digital gauges, but fuel isn't something you monitor full time watching the gauge swing. You can even set it to flash if it goes outside your set point. This would tend to alert you to a fault without having to watch it. EGT is the only thing you rerally need to monitor closely. Boost is what boost is for the most part.
IMHO..the Dodge A-pillar is already too fat and obscures vision. Install does look pretty kewl there tho.
Renegade,
My vote is for the Isspro's. I went 0-60 boost, 1500* rainbow pyro, and 0-30 FP with no isolator....did use a needle valve though. Almost 3 months and over 5k miles....no leaks anywhere, and smooth gauge needle action.
As far as the color...I think my gauges look like they came from DC with the truck. I got green bulbs from Wally World for cheap. The extra stuff on the a-pillar doesn't seem like much more than stock as far as vision goes imo.
I've got pics in my gallery.
Guest
Posts: n/a
I didn't tighten properly the fitting to the FP guage. As a result the guage quickly read zero psi. Took it off Replaced the fitting using loc tight sealer and re- assembled.
Works great.
I also agree that you will have to break off the lower portion of the original A pillar. To get everything to fit properly. From experience, if you don't modify it, the assembly process will.
Works great.
motomac3
09-06-2007 02:44 AM
calvin
01-01-2003 09:51 PM
