Fuel system supply components
Does anybody know what the fuel drain manifold costs, and where I can get one?? Also what is the brass "T" called, and where can I get one of these also?
Thanxs for the info!!
I think the T you refer to is on the fuel return.
There's a port in the cylinder head that unused fuel from the injectors spill into and is brought out of the head with a banjo fitting at the rear of the head.
From the banjo fitting the fuel is plumbed to the aforementioned T then by rubber line sent back to the fuel tank.
those fittings (snap on type) are readily avaliable from parts stores. Careful selection required. The other three way fitting is avaliable from hydraulic shops or can be fabricated from better quality components. Banjo bolt gskts are avbaliable from the hydraulic shops. I found mine at a aeroquip dealer at reasonable price.
Jim Lane
05-03-2012 06:28 PM
ppsi
03-31-2011 07:38 PM
