Fuel Smell Since Repair
I did the pump a month or 2 back so fuel smells should be gone, do you just use a wrench on the lines? thanks for the help truck seems to be nickle and diming me right now
looks like #5 and 6 injector lines were loose at the head I guess i should know soon if that was the problem, my buddie just bought the same truck as mine in 3/4 ton and it was leakin bad from those 2 and they were loose, is this a common problem?
Those last two are the PIA's to get to, mostly #6. I used the recommended torque of 28 ft/lbs and they sealed fine within a short time. Some have said they couldn't get the torque wrench back there, but I had no problem, specially since your lift ring isn't there. I was, however, using my 3/8 drive in/lb with a crows-foot since I cinched the injector hold downs just prior, so maybe the smaller wrench helped out.
i was able to tighten it some(#6) with a wrench then put on a line wrench crowsfoot with a long 3/8" rachet that worked good till I slipped off and smashed my hand ugh but the last 2 were real loose like a full turn or more
If you do the key trick wait a few seconds after p-done shows, then it will check the ecm and show e-done. at least mine does.
Also I agree with DodgeCowboy. If you got diesel on your hands, clothing or boots you can track it into the cab. Especially if you have cloth seats and carpet.
Kurt
Kurt
ted_pulliam
11-20-2009 09:05 AM
Spooler
22
05-06-2009 06:50 AM
PeytonMaterne
08-11-2008 05:25 PM
roberts11260
10-04-2006 08:19 AM
