Fuel Pressure Slowly Dropping
Over the past few months my fuel pressure has been slowly dropping. Its not going to the danger level yet… the most I can get it down to is 12 – 13 psi at WOT and then it goes back up ti 15.5 – 16 psi at idle which is great.. But the reason for my worry is that when I first installed the FASS II it did not have the updated spring and it would go down around 10 & idle at 12. So I got the updated spring and then I was getting around 16.5 – 17 at idle & would not go below 15 no matter how hard I pushed it. So I called where I got the FASS II from and he said the first thing is change the fuel filter (which I just did over the weekend & saw no improvement) the next thing he said is being that my truck has 130k miles on it that its quite possible that the screen in the tank is getting clogged and is causing a restriction when the engine requires more fuel.
Does this sound like what could be causing the restriction & lower FP? And if it does what are my options? Is there a replacement screen? And finally which is easier? To drop the tank or lift off the bed? I have access to a lift so it should make things go a lot easier…
Warmer weather will cause the fuel pressure to drop some. How warm has it been where you are??? If you are measuring fuel pressure in front of the pump..the pickup in the tank should not have anything to do with it. But I could be wrong!
The FASS I on my wifes truck has been on for over a year now...and still works great. I did notice a fuel pressure drop back in July when it was 105* during the day. Now that it has cooled off the fuel pressure has returned back to its normal location..
Rick
Rick
My fuel pressure gauge is hooked up post filter off the engine before it goes into the VP44.. its actually been lees humid here and temps are only in the 80s during the day and 40's - 50's at night... Also I have a gauge that hooks up directly to the vp44 test port, so i'm going to test that tonight to make sure my gauge isn't going...
Mountain Grown
07-23-2009 11:26 AM
Chipmunk Diesel
10-13-2004 06:28 PM
