Fuel pressure isolator and fittings ..?
Old 06-14-2004, 06:09 PM
Administrator / Scooter Bum
Shovelhead's Avatar
Thanks for covering for me guys.
Wifey gets to playing video games on the 'puter and just looses all track of time............
Need to get her a playstation...........
Old 06-14-2004, 06:51 PM
z1bigtom's Avatar
Ok so will a Autometer gauge be ok to run diesel into directley?
Where would i get that needle valve at...?
Old 06-14-2004, 06:55 PM
phox_mulder's Avatar
Pretty sure that Autometers are not approved for Diesel.
That being said, you should be able to find the needle valve at any plumbing supply,
or even Home Depot type store.
phox
Old 06-14-2004, 06:59 PM
z1bigtom's Avatar
Phox...........Just goin thru your pics now of your ride....Looks great......I just got my PA 3" bodylift on friday and will be installing next week.....
6" should look good with 35" SSR's......
Ok back to the FP setup...........So should i use the isolator that came with the gauge?
Sounds like i should...
Old 06-14-2004, 07:00 PM
Thanx.
Yes, if using an Autometer guage, use the isolator.
phox
Old 06-14-2004, 07:03 PM
z1bigtom's Avatar
ok,,,,,,,,,,Now back to my original ( original question)...LOL
Should the isolator be mounted on ther firewall or on the motor.
I thought i read somewhere it was better to mount on motor....Could be wrong though.....Does it matter?
Wanna get this done already.
Old 06-14-2004, 07:09 PM
Shovelhead's Avatar
I would think that mounting it to the body would help longevity, isolating it from all the engine vibrations.
Old 06-14-2004, 07:46 PM
Rattletrap1's Avatar
I have read that sending units for electrical gauges be mounted on the motor...the theory being that vibrations were in sync that way and less likely to give false readings. For a mechanical gauge and isolator I believe firwall, etc. is fine.
Old 06-14-2004, 08:39 PM
rattle_rattle's Avatar
Just be sure to get a diaphragm type isolator, not the cylinder/piston type. There are some longevity problems with that type.
Old 06-15-2004, 03:53 PM
z1bigtom's Avatar
ok thanks..........
01DodgeDiesel
13
07-18-2005 11:07 AM
deezulsmoke
02-08-2005 02:15 PM
jazz_kt2000
11-19-2004 04:49 PM
gaRam
17
09-06-2004 08:39 PM
Jolleyman
08-04-2004 07:31 PM
Quick Reply: Fuel pressure isolator and fittings ..?
