Fuel pressure dropping to 2 psi
Old 01-10-2008 | 10:10 PM
creacy22's Avatar
Hey guys I installed the edge juice with attitude today and of course my Fuel pressure is junk 10 psi Idling between 7 and 9 just normal driving any more pedal than grandmaing it and the pressure drops to 5 or 6 and wot is 2 psi, my question is I'm pretty sure that my lift pump is junk, should I replace it with a stocker or something else, This is all the mods I plan on doing so big HP is not my goal.. Your thoughts Thanks..
Old 01-10-2008 | 10:19 PM
06 DIESEL's Avatar
I would replace it with an aftermarket one, more reliable and better quality IMO.
Old 01-10-2008 | 10:31 PM
mx684's Avatar
i agree...go aftermarket, or you will continue having problems..
Old 01-11-2008 | 11:25 AM
WestTN's Avatar
A big part of the pressure drop is caused by the banjo fittings. Use the Vulcan Re-Lo kit from Geno's to get rid of them when you change the pump. I did, and can't pull the pressure below 12 psi with the Smarty #7 setting and the boost at 28 psi.
38 Cigarette
16
08-29-2015 12:27 AM
schamran
12-14-2009 09:20 PM
nrussell
07-23-2008 09:58 PM
Tommy93w350
08-07-2007 01:15 PM
Dave88LX
15
09-04-2006 10:30 PM
