Fuel Pressure =Zero!
Yea I Am Having Major Issues. My Fuel Pressure Is Between 0-4 psi Going Into My Injector Pump And My Truck Will Not Start The LP is Brand New. Could It Be Losing Pressure In The water Seporator Or Not. The VP44 has No Control Over Pressure Going. In Does It? I hope It Is Not Dead But I Don'y Know. Should The Truck Start With Out Any Fuel Pressure Or With That Low Of Fuel Pressure? Please Any Ideas!! Thanks
I did that and know start and the lines are not spraying anything out. no fuel outof injector lines. With out fuel pressure would the VP44 still be able to suck fuel and spray out of those lines.
You need some fuel pressure at the vp44 inlet or at least you should have. If you have some inlet pressure and you are cranking it and nothing comes out you could have a dead vp44, or computer/wiring issues. Any codes? What is the history on the truck?
The Code Is p-1693 which is a generic code. the truck was not running when i put the new Lp on the truck had died the day before on the high way out of no were. it lost fuel pressure and shut down.
JCHMOTOR
15
06-22-2004 09:25 PM
