Fuel pessure gage problem
Old 10-14-2007 | 07:09 PM
RAM2940's Avatar
Changed fuel filter today and after replacement my fuel pressure gage needle seemed to start floating. The needle would climbing slowly up to 15 psi then when i shut truck off, needle would slowly fall to 0. Do you think its air in the lines(mechanical gage no isolator)?
Old 10-14-2007 | 07:30 PM
P.J's Avatar
P.J
You do have a needle valve in line, correct?
Sounds almost like there is something stuck in-line there, air compresses against liquid the same (not thinking it's the air).
I would bet it straightens itself out after a few runs.
Old 10-14-2007 | 07:47 PM
RAM2940's Avatar
Yes i do have a needle valve, gage has been in truck for a couple years with no problems until today when i changed filter and wiped out the bowl.
Old 10-14-2007 | 09:39 PM
nickg's Avatar
I had the same problem and I ended up pulling out the filter and replaced it with a hastings, cant remember the brand I pulled out (GKI or something like that) was a huge difference in quality, but even with the new Hastings it took a couple of hours to level off, I think until the fuel filter media gets saturated it works against the lift pump
Old 10-15-2007 | 06:09 AM
qwest's Avatar
same problem, air in gage line, it cleared it self after a few days,
Old 10-16-2007 | 01:10 AM
2500Ram's Avatar
x2 same thing I experienced. Give it a few days or about 100 miles, sould be normal then. I don't drive my truck much more than 10 miles a day (work week) so I can agonize the change for weeks.
possum67
02-12-2007 02:39 PM
bocuso
04-13-2006 09:28 AM
shrtmntdiesel
03-02-2003 08:54 AM
JASON T.
10-20-2002 02:53 PM
