Fuel light just flickering?
Hi, I just installed my fuel light, and the first time I warmed it up on the highway, it started to flicker. More off than on, just occasionally winking, not even bright.
What's wierd is if I floor it, the light goes off. If I let off the throttle, the light goes off. It's just steady state throttle that makes it flicker.
So I changed the fuel filter, and the light got better, but still flickers occasionally. The pressure switch supposedly comes on at 8psi. Do you think it's safe to drive? Leaving in 3 days on a 3,000 mile trip.
Michael
Michael
Before I had gauges I had the led warning light and it start to flicker sometimes and then a little while later it started to come on more and more then just stayed on even at idle. Could be signs of a dying lp. You could check your pressures with a gauge, other then that just keep watching the light if it starts to stay on alot then it'll be time to do something about the lp.
