Fuel Leak?
Old 12-22-2010, 09:29 PM
PA90Ranger's Avatar
Fuel Leak?
I recently noticed that when I shut my truck off after driving it about 15-20 minutes at least that there is a small amount of fuel leaking from it. I can see a few beads hanging off the bellhousing, but I can't pinpoint the source of the leak. Any ideas? Everything appears to be tight that I can see. Thanks
Al
Old 12-22-2010, 09:58 PM
torquefan's Avatar
Not sure if you've seen it, but the 24 valves have a banjo fitting dead center on the rear of the cylinder head. It's the fuel return line; it's not possible to actually see it, you just have to know it's there. You can stick your hand back there from around the side of the head and feel for wetness. I think it takes a 17mm wrench to snug it up.
Old 12-22-2010, 11:45 PM
rebal's Avatar
check your filter also it can run down to the back
Old 12-23-2010, 12:29 AM
KATOOM's Avatar
There is a banjo for the head return but its not directly in the center of the head, rather more at a slight angle pointing toward the driver. Yes it can leak but there is also a T-fitting just below it which ties the VP return with the head return and that T-fitting can leak as well. I'm surprised you haven't started experiencing hard starting when the engine is cold or been sitting for awhile during the day.
Old 12-23-2010, 09:52 AM
Junk Man's Avatar
There are grommets in the T fitting on the return line ~ $8 each from Cummins. Free if you can find the correct size hose & cut to fit. Sorry, I don't know the size. T usually does not need to be replaced.
Old 12-23-2010, 01:17 PM
PA90Ranger's Avatar
I checked the T fitting a while back and everything seemed to be tight. I'll check the banjo fitting and if that's tight and dry I'll try to reseal the T fitting. Thanks for the help guys!
Old 12-23-2010, 02:14 PM
KATOOM's Avatar
I understand that dusting the area with talcum powder is an easy way to detect any leak.
Old 12-26-2010, 09:16 AM
PA90Ranger's Avatar
Anybody have a part number for those T fitting seals? Looks like that may be the culprit...
Old 12-26-2010, 12:46 PM
Junk Man's Avatar
Call Cummins & give them your engine number. They can look it up. Dealer was twice as much. Since it is Sunday, try tightening a little. Sometimes that works.
I'm at another machine so don't have either part or engine # handy.
Old 12-30-2010, 02:14 PM
PA90Ranger's Avatar
Seals for the T fitting... Cummins P/N 3905351
Old 12-30-2010, 07:29 PM
bb45's Avatar
leak
did you have any hard start probs im having trouble with mine after all 3 lines from the t were replaced because of a rusted line now starts then stalls and hard 2 restart
Old 01-02-2011, 08:07 PM
PA90Ranger's Avatar
Never had a hard time getting it started. Actually found it wasn't the T fitting leaking. Had 2 injectors lines less than a 1/4 turn loose. Thought it was the T fitting cause the fuel was running towards the back of the motor and down in that area.
Old 01-04-2013, 09:33 AM
iwhitne's Avatar
does anyone have a picture of this...?
Old 01-05-2013, 08:33 AM
bb45's Avatar
lol almost forgot about this thread turned out my problem was a rusty line at the fuel pump. What are you looking for in the way of pics the t fitting is hides behind the rear of thre head would be hard to get a pic but i will try if it will help thanks BB
Old 01-06-2013, 09:33 AM
iwhitne's Avatar
Yeah I reached back and snugged up the banjo fitting on the back of the block, but I'm still getting a little fuel dripping off the bottom of my bell housing. I don't have a cummins store near by to get the rubber bushings and If I had a picture I feel I would have a better understanding on how to fix the problem... I picture would be great if possible!
Quick Reply: Fuel Leak?
