fuel injector leaking
hey i have been noticing diesel on the ground under my truck. i think its the injectors. there is diesel on the block where the injector lines go into the head, i checked all the 3/4 nuts to the injector lines and there tight, wondering if anyone had any other options i could try,
98.5, 24valve, air dog fuel seystem, 300hp injectors, VP 44 injection pump, smarty chip, 5 in exhaust, 58mm turbo,
Cummins Guru
Fuel line or O-ring on fuel tube could be leaking. If line is tight then I would try new o-ring and fuel tube. Make sure fuel line isn't cracked also.
truckdweld
10-29-2011 03:52 AM
ClassA4x4
01-05-2011 10:59 PM
adidasman23
14
11-13-2006 01:14 PM
