Fuel Filter Preference?
Old 01-07-2003 | 12:28 AM
Stamey's Avatar
Who likes what fuel filter, and why?<br>I'm sure I won't use Fram, because if their oil filters are crappy....<br>Are all the rest about the same?<br><br>I was thinking about Napa's fuel filter.<br><br>Comments requested.<br><br>Thanks,<br>Chris
Old 01-07-2003 | 12:39 AM
pappyman's Avatar
Re:Fuel Filter Preference?
I prefer Fleetguard but have used NAPA also without troubles
Old 01-07-2003 | 12:53 AM
BigK's Avatar
Have used Baldwin filters for the last 15 years. Never a problem. Fuel filters seem to have more pleats, and are larger in diameter than Fleetguard. No problem w/Fleetguard, however. Wix makes a good product.
Old 01-07-2003 | 03:39 AM
DarrellB's Avatar
I've used Mopar, Wix, Fleetgaurd, Napa, and Finerluber fuel filters. All have seemed pretty much the same, one thing to consider is the Mopar filter is the most expensive and the Finerluber is the cheapest.(yet they all seem to be made the same) <br><br>I have a 99 so I've got the bottom loading filter with the larger top peace on it. I change the fuel filter ever 10,000miles or every 2 oil changes. 8)<br><br>DB
Old 01-07-2003 | 06:59 AM
Alan_Reagan's Avatar
Fleetguard Stratapore Filters.
Old 01-07-2003 | 11:17 AM
TPilaske's Avatar
Baldwin here... (for everything!) ;D
Old 01-07-2003 | 06:45 PM
chuck3's Avatar
Fleetguard all around.
Old 01-07-2003 | 07:05 PM
KC's Avatar
KC
I use Fleetgaurd from Geno's.<br><br>KC
Old 01-07-2003 | 07:28 PM
Stamey's Avatar
Well I'm a believer now!!! <br>I got a Napa, for now, and installed it. My fuel pressure went up 9 lbs!!! With a stock fuel pump. I didn't think the filter could make that much of a difference. :-[ I was sooooooo wrong. :-[<br><br>With stock pump:<br>Before:<br>5-6 lbs at idle.<br>0 lbs at anything over 1500 RPM<br><br>Now:<br>14.5-15 lbs at idle.<br>11 at WOT.<br><br>I am sorry I did not believe the Diesel Gods. Please forgive me. :-[<br><br>Chris
Old 01-07-2003 | 11:26 PM
DarrellB's Avatar
Your punishment for not believing in the Diesel Gods is 200 miles of driving in a 6.5TD Chevy.
The Diesel Gods have spoken now on to your punishment.
Old 01-07-2003 | 11:38 PM
Stamey's Avatar
I have already done this, and more, does that count?<br>1996 Chevy 3500 rollback (my Dad's tow garage) with the 6.5 TD. It was definitely faster than his other rollback (an 89 C60, with a 368 gas engine, school bus transmission, and a 2 speed rear ??? ), but I was not as impressed with the power as with the Cummins.<br><br>6.5 CTD: 2 injector pumps, fan clutch, 1 clutch, and 1 flywheel, all before the 30K warranty ran out. I think there has been another injector pump since then, out of warranty. :'(<br><br>I'm gonna go polish the Cummins to see if I can make up for what I put it through. (I do have the 1/2 inch fuel lines ordered for it ;D )<br><br>Chris
Old 01-08-2003 | 01:11 AM
DarrellB's Avatar
The Gods will forgive you this time but don't ever anger them again or you may loose your Cummins ownership rights.
All in good fun. ;D
DB
Old 01-08-2003 | 08:23 AM
TXRAM2's Avatar
Fleetguard all the way ;D...I have used a couple Wix in the past and they had Stratapore stamped in the top of them...just f.y.i. <br>wk
Old 01-14-2003 | 11:35 PM
ProspectorTim's Avatar
I get MOPAR fuel and auto trans filters from Genos. OEM stuff for a fraction of the price. Shipping charges are reasonable, and I usually order 2 or 3 fuel filters at a time.<br>Always carry a spare!<br><br>I've found that the filters get changed more often when it doesn't hurt the wallet so bad! :
Old 01-15-2003 | 06:24 AM
admin's Avatar
[quote author=Stamey link=board=4;threadid=9307;start=0#89252 date=1041917311]<br>Who likes what fuel filter, and why?<br>I'm sure I won't use Fram, because if their oil filters are crappy....<br>Are all the rest about the same?<br><br>I was thinking about Napa's fuel filter.<br><br>Comments requested.<br><br>Thanks,<br>Chris<br>[/quote]<br><br>I use Feeltguard and I get my filters from Genos. I kinda like the filter kit you get from them so I've always gone for that in the past.
