Fuel filter housing leak at wiring? buy whole new?
Noticed a fuel leak... coming from where these red and black wires enter the filter housing.. clean it up, wait 2 seconds and its wet again..
Is this a servicable part or do i need to buy a whole new filter housing ?
had the exact same problem, because its a preshur fitting you cant fix it so yes, not the big problem, they want about $1000 for a new one, very hard to find in junk yards, its cheaper to get a fass with the filter and lift pump then it is to get a new houseing. kind of sucks but ull get rid of that troublesome lift pump that way too...
I've helped a couple guys "fix" that issue. Remove the housing, remove the wiring and plug, clean it up good, and have it plugged and welded. No need for a fuel heater in these parts.
I had the same problem. I removed it and plugged it with JB weld but it still leaked. I replaced it with a Glacier fuel filter & water seperator combo for a couple of hundered bucks. Its easier to change the filters and it flows more fuel.
Kinda not near home now.. Ill clean and try some sort of sealant for now and when i get back home where i have a second car ill take it off and weld over it. Is it aluminum ?
Thanks for all the input!
Elohim1
05-22-2010 09:51 PM
Big Smoky
03-06-2006 10:47 PM
j
01-09-2004 08:19 AM
