fruitless search: why get a fuel pressure gauge?
Originally Posted by elandon1201
Its not an opinion its a fact, we all know there are various reasons for a VP failure, please dont ask someone to put "in my opinion" when we all know it is a fact. Yes there are other reasons for failure but 0 PSI will kill your VP. People around here need to realize that common courtesy is the least you can do for your fellow members.
The VP44 can be damaged if fuel pressure drops below 5psi."
when my first lp went bad,it quit pumping for about 15000 miles. my vp was sucking fuel thru the lp.... how i found the problem was when i changed the filter i had to manually fill the canister (3 changes) and the engine developed a stumble during acceleration... so i ckd the pressure, had none ,had the dealer change the lp, all is ok for 40000 miles . changed 2nd pump under warranty, added pusher pump on frame,(per advice from dealer).. end of pump problems except for a broken ground wire a couple of times my current mileage 164,000 miles on original VP 44
Mentioning heat, theres probably people up north in cold climates that have Vp44 failures that never let their tank get below half.. still chalkin it up to heat in that scenario?
Igor
10-21-2007 04:12 AM
doomgaze
03-23-2004 09:28 AM
