front TIRES BURNING ON THE OUTSIDE
Should have checked for BJoint wear when aligned. Big mistake is alignment shops don't pay attention to alignment. Put on green and call it fine. Besides two machines will not agree for most part. Take the toe to near zero. May even go slightlly toe out.
It could simply be you are cornering too fast. With a lift kit you raise the center of gravity of the truck. It will lean more and scrub the tires more. Oh, yeh, and it will also burn more fuel.
Good way to check is jack up the whole front end and pry on the bottom of the tire, see if there is any movement. These trucks are also known for hub problems, especially if ya got oversize tires. And like dozer said, prolly toe. Not always, but worn ball joints tend to make the insides wear. They wear out, and the weight of the truck makes em camber in a bit, wearing the inside tread.
If your ball joints are shot then it's a different story, maybe they didn't check them?
Now if your truck was aligned properly, you shouldn't have any outer tire wear. If anything, you should have inner tire wear because these trucks use a solid front axle, that's why it's important to rotate your tires on time. My bet is, they didn't align it properly. The "green" zone is too broad on the machines and these trucks need closer alignment.
See this thread for specs:
https://www.dieseltruckresource.com/...ht=ball+joints
you guys are the best, Nick02ram, i went to a mechanic shop and he did what you said to do, with a pry bar, all my ball joints are shot. The thing is im going to get him to pay for my alignment cause he should have check that **** out when he was doing it the first time. You guys are all great. Amazing form boys.
ppsi
10-13-2011 07:35 PM
1320
05-29-2009 10:24 PM
ronc
14
02-13-2009 11:14 PM
CRSmith
05-01-2007 06:45 AM
sakisaki400
23
12-31-2006 10:17 PM
