Front suspension rattle
Has anyone repalced the radius arm bushings or arm themselves yet?<br>There is a rattle in the front end and I have checked the lug nuts, the wheel bearings, the steering linkage, and replaced the track bar end. There is a rattle that is evident even at slow speed on a gravel drive. Thinking either radius arm bushings or sway bar bushings.
Re:Front suspension rattle
diddo<br>u need to put in I believe a 9/16 bolt and nut to cure this<br><br>hole in shock is bigger than bolt and shock moves in the shackle<br>
I have the same problem, if I touch the brakes just a little it gets quiet. On mine it is some part of the brakes, done that since it was new. I don't worry about it.
case310350
06-23-2010 09:03 PM
mtnman006
24
09-08-2009 03:14 PM
getblown5.9
02-02-2006 07:59 PM
SmokinDodge12V
16
03-10-2004 07:19 PM
