Front end problem.
Front end problem.
When turning, I get a grinding noise from the front driver's side wheel that sounds like all-terrain tire noise. I am suspecting wheel bearings. I also get a clunking noise when braking at slow speeds, which I suspect might be ball joints. What do you think? Could the sounds be related and be just the ball joints? I would like to upgrade the ball joints. What would be the best aftermarket ball joint to go with?
U joint? I never would have guessed that. In the past, when I have had the honor of a U joint going out, I heard a jingling noise from the drivetrain. The vibration I am feeling is only at slow speeds, 10 mph, when I'm turning in a residential area without the use of brakes. I don't seem to get any vibration at higher speeds. Thanks, I'll check out the U joints first.
BTW: Not to sound like a complete bozo ... why would I be hearing the noise up front, and only when I'm turning, if it's the U joints?
No 4WD, she's 2WD, so I guess that's not my issue? The noise is a rumbling, like the sound of knobbie tires, which vibrates through the floorboard. It's very annoying. If it was wheel bearings, the noise should be there all the time, would it not?
The front brakes were done by the dealer approximately 5k ago. I initially thought wheel bearings, but was sure the dealer would have addressed that issue. I did pop off a grease cap to check that they had repacked the bearings and they were nice and clean, with fresh grease. Short of tearing it down to the axle, I'm at a loss! Do you still think it's wheel bearings?
Also check the front wheel bearing adjustment. If they are too tight, they will growel, for a while. If so, take it apart and check the bearings and repack them.
Here is how to check for the WB in the front. Jack up the front end a little pit (just to get the tire off the ground). Grab the top of the tire and push it in and out. When you do this, if the tire moves, get yourself a new set of WB's. As for the ball joints, that is a bit more difficult. You can't simply grab the tire and move it. If the front ned can od that, you got MAJOR problems, and the ball joints are WAY shot. You SHOULD take a crowbar and shove it between the ground the tire. Try to lift the tire. If you can do that, replace your Ball Joints. Or do what I did, and just swap them out with the bearings.
BTW, as for good Ball Joints. I only use Spicer joints. Stay away from everything else.
Dima
Dima
Hey just a suggestion but I was having a similar problem when driving at slow speeds and when turning. I took it to the dealer and they told me my tie rod ends where going out I replaced them and that seemed to take care of the problem.
Ok, I think I solved the mystery!
I crawled under the truck today and noticed the plastic wheel-well liners had rub marks on the back. I started the truck and hard cranked the wheels. To my astonishment, I noticed the tires are rubbing on the rear portion of the plastic liners. I have 265/75/16's; they shouldn't rub, should they? I have noticed that my truck sits lower in the front than the rear; is there a way to lift the front a little to eleviate this problem? I was thinking about trying to fit a 285 later on down the road, but I guess that would be impossible.
