Friction Modifiers for Auto Trans?
I've heard of guys using friction modifier additives in their ATF, anyone know what to use and where to buy? I kinda think my trans may have slipped a little while towing a medium wieght load, pavement was wet, but it seemed like trans, and it wasn't locked up at the time...
What WestTN said ! Friction modifier will make the oil more slippery. We use it on Caterpillar equip. that use wet multi-disc brakes in the differentials when the brakes get too jerky or shudder. Be very careful how much you add if you use a friction modifier and follow the directions on how much to add to your fluid capacity. This isn't one of those things if a little is good, a lot more is better. You can make the clutches in a limited-slip diff. useless by adding too much. Lube guard is fine if you have a new trans or clutches and you are getting a little shudder on clutch applications, then it would help smooth out the clutch applications. Otherwise I wouldn't use it. Just my $.02 worth.
Regards, Mike.
Regards, Mike.
I second lube gaurd. Dave Goerend told me it is what he recommends and he even sent me a bottle with my trans. If it is good enough for Dave's transmissions it's got to be good stuff.
lube gaurd makes a little capsule container called tranny dr. maybe has 3oz. of highly concentrated in it if it helps then you can use the black bottle after a good flushing and filter change ( according to mfg. paperwork)
Friction Modifir For Auto Trans
You have me confused. I just changed the tran fluid today and have not installed the Lube Guard at this time. My tran has 80k on it. Do I wait until problems or pour in the Lube Guard now? Thanks for stearing us correct.
Shudder and slipping are two different things. If its a shudder the lube guard will help, if its slipping then nothing short of a rebuild will help.
DTT recommonds filling thier trannies with Dex3 and a bottle of red lube guard.
BigBully
11-24-2006 02:50 AM
Mike B
09-29-2006 06:26 PM
I PASS GAS
06-12-2006 08:40 AM
Crimedog
06-22-2005 04:37 PM
