Found 02 2500-3500 Hub Conversion!
Old 05-13-2003 | 08:57 AM
Dieselhead's Avatar
This place:<br>http://www.rightgear.com/welcome.htm<br><br>Cost=$1250<br>Installation= About 4 hours. Simialar to changing ball joints<br>ABS= ABS must be disconnected to run this conversion<br><br>What do you guys think? Anyone have any experince with this place? Will disconnecting the ABS be a problem?<br><br>Dynatrac does not make a hub conversion for 00-02 rams due to the outer knuckle change but this place does. <br><br>I will soon be running 11&quot;s of lift up front so I may buy this kit.<br><br>http://www.cardomain.com/id/rattlindodge
Old 05-13-2003 | 12:53 PM
geer's Avatar
Re:Found 02 2500-3500 Hub Conversion!
Are you talking about the front hubs?
Old 05-13-2003 | 01:16 PM
Copenhagenjunkie's Avatar
That's cool, I wonder how much they cost.
Old 05-13-2003 | 02:20 PM
Haulin_in_Dixie's Avatar
What am I missing? All pickups use an adaptor for the front wheels to convert from single wheels to dual. I am running adaptors both front and rear with good results. My ABS works just fine.
Old 05-13-2003 | 02:48 PM
Dieselhead's Avatar
Re:Found 02 2500-3500 Hub Conversion! (Clarification)
Huh???? I'm talking adding front locking hubs to a 00-02 2500 or 3500 guys! Sorry I didn't make myself clear :<br><br>This will particlularly help guys with the 02s because that front axle disconnect was eliminated in 02 with the D60 front so the driveshaft spins all the time. With manual hubs, the ds will be constantly spinning
Old 05-13-2003 | 02:49 PM
Dieselhead's Avatar
[quote author=Dieselhead link=board=4;threadid=14661;start=0#137675 date=1052855295]<br>Huh???? I'm talking adding front locking hubs to a 00-02 2500 or 3500 guys! Sorry I didn't make myself clear :<br><br>This will particlularly help guys with the 02s because that front axle disconnect was eliminated in 02 with the D60 front so the driveshaft spins all the time. With manual hubs, the ds will be constantly spinning<br>[/quote]<br><br>Ooops I meant, with manual hubs, the ds will NOT be constantly spinning!
Old 05-13-2003 | 03:06 PM
tileman's Avatar
Thats nice wonder how it holds up. <br><br>On our 02 3500 4x4 the front truns all the time and that bites.<br>May look into soon.<br><br>Ron.
Old 05-13-2003 | 03:25 PM
phox_mulder's Avatar
I just removed my front driveshaft to try to hunt down a vibration that started when I put my 4.5&quot; lift on.<br><br>Vibration is gone and I noticed, according to the trip computer, that I'm getting 2 mpg better than I did with the front driveshaft on.<br><br>Now I have to decide how to go about fixing the vibration and hopefully keeping the 2mpg I recieved.<br>But, as I have no bombing funds left, that $1250.00 ain't gonna happen soon :'( .<br><br><br>phox
Old 05-13-2003 | 03:50 PM
Dieselhead's Avatar
[quote author=phox_mulder link=board=4;threadid=14661;start=0#137687 date=1052857534]<br>I just removed my front driveshaft to try to hunt down a vibration that started when I put my 4.5&quot; lift on.<br><br>Vibration is gone and I noticed, according to the trip computer, that I'm getting 2 mpg better than I did with the front driveshaft on.<br><br>Now I have to decide how to go about fixing the vibration and hopefully keeping the 2mpg I recieved.<br>But, as I have no bombing funds left, that $1250.00 ain't gonna happen soon :'( .<br><br><br>phox<br>[/quote]<br>You might try attaching it to the front pinion, test it, and if it vibrates, then remove the ds from the front pinion, jack the truck up, rotate the pinion 180 degrees and then retest. Those things are real touchy and if you don't mark and reconnect them in the same places, you could get a vib. Worth a try anyway.
horselady
05-27-2011 09:19 PM
KirtW
The Tire Club
0
05-18-2011 02:44 PM
Rafter B
01-11-2009 08:40 PM
DiEseLjunKy
32
12-27-2007 07:37 AM
SOhappy
07-11-2006 06:35 PM
Quick Reply: Found 02 2500-3500 Hub Conversion!
