Finally, ready to go in...
Old 01-28-2004, 11:11 PM
Haulin_in_Dixie's Avatar
Here it is ready to go in.
Old 01-28-2004, 11:18 PM
Dr. Evil's Avatar
looks great...I assume you did much of that yourself.....
Haulin, Im curious why you wouldnt go with a rebuilt 12V???
Old 01-29-2004, 12:56 AM
I seriously considered the swap and if I had not found this block I probably would have. I am not finding a lack of lifetime of the 24v and I have a fortune in 24v stuff. The injection pump is near new, ATS, EZ, FASS, recent RV275's. The engine impressed me when I tore it down and found the condition with the miles I have on the truck and the work it has done. I will plan on oil system upgrades which is a shortcoming of the Dodge, but the 12v shares this problem also with too small an oil capacity. Will be going to a larger bypass system to build on the oil volume and filtering. Were it not for the thermostat problem, the original engine would easily have made another 200,000. I expect to get 500 out of this one with probably another injection pump. The system is working well for the work it does. Two more gages have to be added, oil pressure and temp in real manual gages. Now, if I could shoehorn an 8.3 in it..... I am also anxious to see how the torque cam handles the loads.
Old 01-29-2004, 01:25 AM
tmoore's Avatar
haulin, I'm just courious how many miles were on the original engine, what what happened to it?
Old 01-29-2004, 01:30 AM
rjordan's Avatar
that looks great! good luck puting it in. i'll bet that'll be fun
Old 01-29-2004, 09:05 AM
ammo5797's Avatar
Good Luck!!
T-stat cost me the motor in my other truck last year....
Old 01-29-2004, 11:35 AM
Look for my thread in the 24 valve drivetrain section, "Important.... cooling system problems"
Old 01-29-2004, 06:45 PM
Dieseldude4x4's Avatar
Can we assume you're going to dyno that set up and let us know how it turned out?
Old 01-29-2004, 07:20 PM
DPG
DPG's Avatar
Looks great, Haulin', how's the arm?
Old 01-29-2004, 08:02 PM
Arm's fine, body ain't worth a crap Engine is in the chassis, took me seven hours to do the flywheel housing, clutch, sink it, oil pan and motormounts. Took forever to get the trans lined up and then the darn motor mounts, they never line up, finally ran a chain through the bumper, pulled it into place with a comealong. The right side always wants to be 1/2 inch back. Rubber disk gets balled up going in. Ahhh it's in.
Probably a days work left, can't do it tomorrow, have doctors appointment at Vets. That will take all day Be running this weekend though. Long as it don't rain every day.
mviverit
04-25-2009 10:55 AM
DNRCustoms
08-08-2008 12:51 AM
ROCKNRAM
12-03-2007 02:19 PM
manganos
03-12-2006 10:42 PM
F11Engineer
03-11-2003 07:43 AM
Quick Reply: Finally, ready to go in...
