Fass
Fass
We have an 02 dodge and getting ready to put a FASS 95 gph. pump kit from vulcan performance. With the big 3/8 fuel line and fiitings and the big line from filter to injector pump. How is the setup seam to be holding up for you guys is my first question and about how long am i looking at for me to do the install. Do i need any special tools or any thing or any problems i may incounter please let me know first time trying to do this. I dont think i will have much problem.
The FASS pumps are certainly one of the best out there. How to mount it is subject to discussion. Some folks mount them to the floor support under the cab, some mount 'em to the frame. One thing to be sure is that the small hole in the pump body faces down. Other than deciding how you want to mount it the installation is fairly easy. The Vulcan big line kit is a simple line swap. The fuel line will need to be tie-wraped since it won't fit where the old line was. Heat the hose ends before pushing over the fittings. They are a tight fit. Here is a recent thread on pump install. I did a frame mount since it is quieter. https://www.dieseltruckresource.com/...d.php?t=209289
Mount the pump to the cross member of the bed, not the frame of the truck. It's the only way it can be mounted and still come out like the instructions make it sound. Right in front of where the driver's side leaf spring hooks to the frame. There is a bed cross member, mount it on that, either side (front side or rear side). I mounted on the front of that cross member.
The blue pinch clip DOES NOT come off with the fuel line (when you unhook it from the tank). You have to pinch it together and pull the fuel line off with the other hand. It's impossible to do, but you have to do it. After you get the old fuel line off then cut off the blue pinch clip with dykes
The instructions are pretty bad. They cover several different versions of this system, but they don't tell you that. I just unhooked the stock lift pump and left it there. I ran the big blue hose from the Fass to the input side of the stock fuel filter. You have to change the fittings on the stock fuel filter input side. Disconnected the wire from the stock lift pump and hooked it to the Fass harness.
It's much simpler to do than the instructions make it sound. They need to be rewritten
Thanks Greg i was just trying to get some idea on how this all would go together my pump i hope will be here today and can start this weekend thank again for the info. Joe
Be prepaired for a fight with the fittings on the tank, they are hard on your hands. I used different hose than what FASS supplies because the hose they give you is not biodiesel safe and since I run B100 I did not want to have to change them in a year. The bed cross member is the place to put it, you might want to use some rubber washers to cut down on the noise.
Here's a hint about getting the old fuel line off the tank. Cut the hose about 4" from the clips, then you can turn it so you can press both clips in together. When the tank was installed, some EVIL person put it on so one of the clips was facing down. I mounted mine to the truck box cross member also and also left the old lift pump on the motor.
I have not installed the big line kit yet, probably will this winter. Love that fass though, works well at -43, great product but the instructions do need some work.
Where are you guys relocating the pumps to on the 4x4 short box quad cabs. I want to stay inside the frame but the fuel tank , transfer case, and skid plate all seem to make it very difficult to find a decent spot..
I had to mount mine on the outside of frame on passenger side as my running board brackets were in the way' it was lower than what I wanted so I put a
rubber flap around it
And the instructions are going to be rewriten here soon......
BCarmicle
13
11-07-2005 04:20 PM
Buckshotmckee
05-23-2005 12:08 AM
Flatty
04-25-2005 12:49 PM
