Exhaust Diameter and Mileage
Need a new exhaust turbo-back on my 01` HO-6spd. 3.54 ratio Van-Aken box otherwise stock.
Used for modest towing/8,000lbs and driving empty.
Does the exhaust diameter used effect mileage?
Seen where it can effect other brands of diesels.
From: In Oroville, Ca., same house for past 46 yrs!
I have 4" from the turbo back in stainless. When I dropped the CAT and went to 6" stacks I noticed a little improvement, went from 17 to 22 mpg on the highway.
I had 3" straight pipe on my 12valve, & added / had it made into duals, & after a few days noticed it breathed alot better, had better throttle response & more torque (opened up the restriction a bit). Was it a miracle cure? No, but it definitely made a difference
don't go any bigger than a 4"... you will loose back pressure and horsepower...
a 4" exhaust can support up to over 500hp.. so unless you're going to be adding a ton of performance parts the 4" would be plenty
I have not ever lost MPG from the larger exhaust.. Had 4" with stock turbo, Went to 5" (with 5"-51" Donaldson muff) when I changed to Silver 62 and kept the 5"(straight from Turbo to tailpipe) when I changed to to stock/S475 compounds.. Only time I lose MPG is when I am pushing o the long peddle more than trying to go light on that same peddle.
I have a 2001 6 speed also, and was wondering the same things. When pulling my trailer I usually run EGT's between 900 & 1100 degrees pre-turbo right now with an EZ box and everthing else stock. I was wondering how much a 4 inch exhaust would help bring down the EGT. I also would like to know what system I can put on that won't be too loud or have a drone when pulling my trailer.
My 98.5 Cummins powered Ram has 112.000 miles on it and the stock exhaust system went south. Installed a 4" Bully Dog stainless turbo back exhaust last week. Really like the sound, and so far have increased my milage from 19 MPG Highway to 22 MPG highway. Wish I had done this years ago.
ne14jpn
02-22-2007 05:56 PM
NoSparkplugs
09-01-2005 05:32 PM
