everyone loves the lift pump
Old 05-05-2005, 06:29 AM
CTD NUT's Avatar
Old 05-05-2005, 11:29 AM
CORed's Avatar
Shovelhead... care to share with the rest of us regarding the $130 LP???
Or at least explain why not if you cannot? Thanks!
Steve
darrenG's Avatar
i'm thinking it will be the lift pump.
is the F.A.S.S. worth it? And Shovelhead...wanna send me an email too? Preferably one w/ the place to obtain a lp?
Old 05-05-2005, 11:46 AM
Administrator / Scooter Bum
Shovelhead's Avatar
You two have mail.
Old 05-05-2005, 11:53 AM
CTD NUT's Avatar
Hey Ed,
You are quite popular today!
Old 05-05-2005, 02:30 PM
RAM2940's Avatar
Before you keep flooring the petal and blow the injection pump you need to make sure you have good fuel pressure.
What rpm's are you turning in 4th at 70 mph. Is the engine hesitating or stumbbling?
Old 05-05-2005, 10:02 PM
darrenG's Avatar
no hesitating and no stumbling. the rpms were under 3k in 4th (i have 3.55's), i wouldn't expect a lot of power there but 5th wouldn't pull. I'm guessing the waste-gate was stuck open.
I don't floor it often - I want this puppy to last a looooong time. i'll know the pressure tomorrow. I'm having it checked when I'm @ work. This will be the first time in years I've let someone else look @ my junk.
Old 05-07-2005, 09:38 AM
Muted User
screaminbanana's Avatar
Originally posted by Shovelhead
The rubber return lines have a reputation for developing small hairline cracks that don't leak fuel, but allow air to get into the system causing a loss of fuel prime which results in hard starts.
How do you check that? What is the part number for it so I can order some for my truck (and where to order from?), its probably cheper then a vp44 or a lift pump.
Old 05-07-2005, 10:38 PM
darrenG's Avatar
does fuel economy drop with the vp or lp dying?
Old 05-09-2005, 06:22 PM
Shovelhead's Avatar
Update:...................
New $129 pump arrived, new pump installed.
New pressure @ idle 16 psi.
New pressure @ WOT 11 psi
Old pump at idle would show 15psi , then drop to 10 psi and hang there..
Once engine RPM was over 1,000, pressure would jump back up to 14-15 psi.
2,000 RPM cruise was still 13 psi, & WOT never dipped below 10 PSI just like always.
All electrical connections were clean, fuel filter looked good.
Weeeeeeird, but the new pump seems to have fixed the trouble.
I'm gonna tear into the old one later and see what the trouble might have been.
Old 05-10-2005, 11:36 AM
CTD NUT's Avatar
I know what you mean....Sometimes pressure on my LP is higher when you would expect that it should drop because of an increase in fuel demand. Weird to say the least.....I have been told it is the needle and seat that is wearing out that causes the erratic pressure fluctuations.....who knows? Let us know what you find when you are finished with your LP autopsy!
Old 05-10-2005, 01:16 PM
Shovelhead's Avatar
On another note...........
The "site" for the $129 LP has just raised the price to $139
Hope you all acted quickly enough to get in on the cheaper price.
ABDTR #5
09-22-2011 10:13 AM
rbrettctd
08-15-2007 03:15 PM
mhuppertz
01-12-2007 09:32 AM
Timberman
0
09-17-2005 03:06 AM
dieselnewbie
07-26-2004 09:18 AM
Quick Reply: everyone loves the lift pump
