Error codes
Error codes
Hey i have a 2000 dodge ram 3500 5.9 diesel truck
go easy on me im new to this haha
i have error codes
pcup1693
pccuo234
and
po216
I want the edge performance in cab adjuster and i think my lift pump and injector pump are gone. The truck works but when u first turn it on it runs to 2000 rpm and once it heats up its fine. What do i replace so this dosnt happen again . Rebuild the injector pump and buy a performance lift pump??
i have error codes
pcup1693
pccuo234
and
po216
try installing a new lift pump but 0216 is a bad code to get 0234 is an over boost piers or blue chip diesel will help you out also get a fuel pressure gauge asap so you can keep an eye on the LP. bummer man
Greg, the only "performance lift pump" is the FASS or FASS2:
http://www.dieselpp.com/
They are $500-$700 Canadian. Available from Piers Diesel Research or NADP:
http://www.piersdiesel.com/
www.nadp.ca
www.nadp.ca
exwrestler
02-05-2010 09:34 AM
sallyman1
08-26-2008 06:20 PM
