Erratic oil pressure readings
I have searched around and see that there seems to be a fair amount of problems with the oil pressure gauge on my style of truck but nothing that sounds similar to my problem. Sometimes when I turn my key to the ON position (not running) the oil presuure gauge will go up to the top of the NORMAL range then when I start the truck it will drop to zero for a little then come up to the top of the operating range again and stay put. I will drive for a while and it will drop to zero for a few minutes than come back up. I though at first it was a bad connection on the sending unit so I checked that and cleaned it, still acts up. Any ideas?
OK I took out the dash cluster to make sure there couldnt be a bad connection there. Double checked the connection on the sending unit and put some dielectric grease on it. Just like before, half the time if I turn the key to the ON position (engine not running) the gauge will go to the top of the operating range and stay there even after I start the engine and will not move at all. The other half of the time the gauge will not budge when I turn the key and will stay at zero after I start the engine. I although I have not put an oil pressure gauge on it Im sure this is some kind of an elecrical issue. Why would it show pressure without the engine running?
streetsmoker
11-24-2008 02:20 AM
xxwildbillxx
06-15-2008 05:59 PM
muddybeast
11-09-2006 08:29 PM
