Engine temp up yesterday
Ran the A/C for a few minutes in stop and go traffic yesterday. Engine temp came up to about 205 F. It was hot yesterday and this is the first day it's done this. Idle was a little erratic for about ten minutes, then perfectly normal again. Going to check the basics here at lunch but wanted to get other opinions. I appreciate it.
Thanks,
Tim
Thanks,
Tim
bet ya need to clean yer radiator ,spray some degreaser or soap on it let it sit then use the water hose inside the fan shroud ,your gonna be suprised what all comes out
Here is what I would do, pull the puke bottle and relocate it. Then pull the rad and throughly wash it. Here are my before and after pics. Now is a good time to flush the cooling system too.
https://www.dieseltruckresource.com/...7&ppuser=61630
https://www.dieseltruckresource.com/...6&ppuser=61630
https://www.dieseltruckresource.com/...n_fan_side.JPG
I also tried to wash it without taking the rad out. You can tell by the pictures that did not work too well....
Subliminal
03-14-2017 06:25 PM
MossyOakCTD
19
12-28-2010 09:11 PM
