engine and rear end oil choices
what engine oil are most of you using? also wondering what type of rear end oil is best and if i need to ad an additive for my limited slip. getting ready to change fluids for the first time on "new" used truck. thanks for the help
Guest
Posts: n/a
Re:engine and rear end oil choices
Rotella, Delo, Valvoline Royal Blue, Amsoil - all 15w40 will work just fine. Just keep it changed. <br><br>I swapped over to a synthetic in the diff. I am using amsoil now but in the past I used mobil 1 and still put 1 bottle of friction modifier.
Amsoil offers 2 different lubes for the rear, one for LS and one for open rears. You should not need friction modifier with Amsoil.<br>I'm running Amsoil front to rear, but do not have an LS in the rear.<br>I just changed my engine oil with 16K on it, and took a sample. The analysis came back stating I did not need to change the oil. I'm goin for 20K this time, and will start sampling at 15K. ;D<br><br>Chris
Valvoline Premium Blue in motor. Fleetguard oil filter! Valvoline 80-90 and two bottles of Mopar friction motifier in the differential.
Stargeezer
24
01-28-2012 08:04 AM
TNLoneWolf
12-04-2007 01:27 PM
doorguy
06-08-2007 06:19 AM
