EGT questions?
It's not the temperature that matters. It's the heat. So that means temp*time.
Do not sustain more than 1200 on a steady pull and you'll be fine forever. Keep the RPMs up and it will help.
This is pre-turbo pyrometer temp. Do not use a post-turbo location if *engine* health, not *turbo* health, is your concern (as it generally should be).
JH
Well said Justin!
It's not how hot you get....it's how long you stay hot!
I've seen guys run 1800* at the 1/4 mile strip...... but only for 6-8 sec. This causes no problems.
I saw a melted piston on an 01 HO that pulled a heavy load for 4 hrs at 1200* egt. (65 mph, 6th gear, low rpm).
I always follow the 10 sec rule. Never over 1200* for more than 10 sec in a row. This is a little overly conservative but that's just who I am.
RJ
RJ
jmccart
03-18-2007 11:03 PM
jmccart
14
11-20-2006 07:45 PM
