EGT discuss
EGT discuss
My rig is in my sig line, just got the Edge J w/ A installed and the EGT's seem high?
What is an acceptable peak EGT on a short burst (I see over 1300º on level 5) what is an acceptable sustained EGT while loaded/towing? I'm around 900-1000º on level 2 towing about 7K up a 6% grade.
I searched and couldn't find what I was looking for.
Other than what's listed in my sig, my truck is stock as far as I know. I do have a new IP and Carter LP installed prior to my purchase
Thanks
Thanks
Thanks
So more fuel = higher EGT's?, but more fuel = more power? I'm not buildin a sled puller so I want economy and power when I need it as well as longevity.
What EGT's are safe depends on where the temp probe is, pre-turbo or post turbo. If your probe is pre-turbo, the above temps are a good guideline. If the probe is post-turbo, you need to look for temps that run 300-400 degrees lower. That is, 950-1000 degrees is close to the upper limit.
What exhaust are you running? 4" or 5"? Is it a cat back or a turbo back? The Banks Monster is a 5" isn't it? I just saw it in your sig.
Kurt
Kurt
I have a 4" system from Banks, it says Banks Monster on the straight through muffler, it is also a turbo back, my truck is non catalyst from the factory.
Joe T
16
04-20-2007 07:16 PM
