Edge-attitude plus raptor = questions
Just got my Edge Juice with Attitude CS 31000 wohoo (ok mild excitement),
I have a Rp-100 Raptor lift pump; and I’m not sure where to hook up the fuel pressure sensor that comes with the Edge Attitude harness; Am I going to have to buy a new banjo or fitting? Hopefully not….(1999 manual trans, 4x4)
The kit comes with two options im just not sure wher eto install them
I have a cap for my fuel filter that has a port in it to test fuel pressure. That is the easiest way to go BUT it isn't the most accurate because it measures fuel pressure before the filter not after. The cap came from Geno's Garage. The banjo is the recommended method.
on the 99 filter housing, there's a pre filter port and a post filter port. my gauge is hooked up right at vp44 at the banjo bolt but was installed by previous owner and I'm not exactly sure installing directly next to vp44 is a good idea. I would tie in closer to the filter.
84mphcdt
16
12-19-2007 11:31 AM
CDoskocil9
01-10-2007 12:16 AM
joelegs1000
07-27-2005 10:28 PM
