Drive Train Fluid Change
I am going to be doing drivetrain service
I need some info
Oil Type and quantity for:
Front Diff
Transfer Case
Transmission 6spd standard
Rear Diff
Thanks in advance
I need some info
Front Diff
Transfer Case
Rear Diff
Thanks in advance
Well i just did all that a few weeks ago. Heres what i used. Pennsoil 85W90 in the front and rear diff. I added a bottle of Mopar Friction modifier in the rear because i have Limited Slip. I used Dextron III ATF in the Transfer Case. I filled them all up until the fluid started coming out the fill hole then i put the plug back in. I have an Auto so i dont know what fluid you should use in your Manual Trans.
Most all service items can be found by clicking here>
http://dodgeram.org/tech/repair/index.html
I don't know what year your truck is but since your in the 24v section this link might be helpful.
1994+ specs.
Also you can fill the transfer case to the bottom of the fill hole, but the front diff should be 1/4" BELOW the hole +- 1/4" and the rear diff should be 3/4" BELOW the fill hole +- 1/4". Too full conditions have been known to cause the seals to leak.
1994+ specs.
You can also buy an owners manual here for under $10
http://www.techauthority.com
Lary Ellis (Top)
55
11-08-2012 10:22 PM
Tiara3100
12-28-2004 06:50 AM
