Diesel fuel mixing with my engine oil?
When checking my oil it is always overfull. Even after an oil change a short time later it is more full that what I put in. Any ideas on a way to locate the problem? It is a 2001 Dodge Ram 2500
If it is saturating with diesel you have a leaky injector or worse a hole in a piston.
A leaking injector would have other symptoms also, like loss of power, rough idle, smoky exhaust....
That is where I would start investigating.
Been there, copper washers on the injectors leaking fuel as well o-rings on injectors clean and change to start, even transfer tubs O-rings to start. If it still persists than I hate to say its the injection pump seal but do the first its the cheapest, or upgrade injectors at that time
If you are getting that much fuel in the oil, I would be very hesitant to run it until it's fixed. Fuel/oil dilution will compromise the oil's ability to lubricate, putting your bearings, camshaft, lifters, rocker arms, valves, and everything else that moves inside your engine at risk for lack of proper lubrication. The more fuel in the oil the greater the impact.
Fuel oil dilution is something we test for daily on our large diesel engines on our cutters/ships if they have low pressure injection/fuel delivery, and every 4 hours if the engine has high pressure injection and/or high pressure lines are internal to the crankcase. That included main propulsion engines and the generators. Fuel oil dilution/oil thickening is tolerable to a very limited extent (don't remember the specification off hand). Beyond that limit signals there is a problem with that engine.
Hope you get yours figured out soon.
dozer12216
11-24-2008 02:03 PM
sonnys
07-17-2008 11:41 PM
redpoint5
36
02-08-2007 05:07 AM
sweetwaterguy
35
12-29-2006 11:48 AM
