Died while shifting into 3rd, won't restart
2001, 2500, no mods, yesterday I was driving shifted into 3rd, engine died, cranks, won't restart, bought Code Reader and checked codes, has the following Codes, P0252, P0251, and P1688, I know that the codes are, need to know if i will have to replace the Injection Pump.
Welcome to DTR
Sorry for your situation, we'll help all we can and then some.
Do you have a fuel pressure guage?
P0251 = Injection Pump Fuel Valve Feedback Not a good thing.
I finally was able to get a guage and get to the truck, I checked fuel pressure at the test point no the side of the VP-44 and had 11psi, on key cycle. I did not have a wrench to crack an injector line, will get back to the truck in the morning.
Thanks for any and all help
I had more time today to check it out better, I checked fuel pressure on the side of the VP-44 inj. pump, it had 11psi at key cycle and droped down to 2 psi while cranking. I then checked fuel pressure on the side of the of the fuel filter and had the same results.
The Dodge service manual states
Fuel Transfer (lift) pump Pressure with engine running Min 10psi. (engine won't start).
Transfer (lift) pump Pressure with engine Cranking Min 7psi.
So with the results I got i changed the transfer (lift) pump, well i got a bad one, cycled the key about 20 times and only 3 times did it ever pressure up had about 15psi, but then when i cranked on it it droped to about 5psi. I then poped the inlet line loose and could not feel the pump pulling a vacuume. Tomorrow i will put a vacuume guage on the inlet side to verify.
2001, 2500, 4X4, quad, all stock.
Well the LP died and took the VP-44 to the grave with it.
I'd like to thank Midwest Fuel Injection, Kevin is great to deal with and very helpful. I recomend them Highly.
Thanks for the info. on this and the other posts i had questions on.
popeyesides
20
12-19-2009 07:29 AM
02Texas_Rattle
08-29-2004 09:10 AM
