Dealer wants to replace original LP.
I have been geting the "dead pedal" deal every once and a while. The dealer wants to replace the original LP with one in the tank. Is this good or bad?
The truck has 80k miles. The dealer will replace the Lp under warranty. Is the new pump that goes in the tank worse than than the original?
Does anyone else have any comments about the replacement LP. Thanks for the information. I just want to make sure I make the right decision.
The pressure the "new" pump puts out is a little less than most of us would like to see, but the jury is still out on the longevity, which has been the single BIGGEST issue with lift pumps.
Get the in tank, later on, if you want you can add another pump to run in tandem with that one if you desire.
I had two of the original pumps die on me before the 'in tank' pump was introduced. I've now got ~30,000Km on the in tank model and it's worked fine.
I've got no info on what sort of pressure it's running.
What is the benifit of adding a second pump or increasing the pressure?
Probably not a big deal in a stock, non heavy towing application.
I have the in-tank pump on my '99. I just installed a fuel pressure guage. Its a 15psi guage, and its pegged at 15 or more at idle. If I really romp on it, It will pull down to 10 or 11. I figure if I continuously see it at this level, then I'm fine. If it starts to drop at idle, or go below 8 or 9 with my foot into it (very rarely with the price of fuel these days!! ) then I'll have to re-wire and mount one of the FASS pumps on the rail.
I think its MANDATORY that you get and install a fuel pressure guage. I got a pretty cheap one at Geno's Garage (online) and it was pretty simple to install. If you aren't handy with this kinda stuff, or don't have a good friend like I do to "assist" you, then I would even pay the bucks at a diesel shop to have them install one.
Again, I don't think the in-tank pumps are the best solution, but as long as you keep an eye on them, just like anything else - - it may work fine for you or it may crap out in a matter of a couple thousand miles.
Thanks for the information. I Called the dealer. They said they may have to also replace the Injector pump. I told them I have been geting some "dead pedal" and had a "Injection Timiing Malfunction" code. The truck seems to be very sluggish and I can only get about 14-15 mpg out of it.
Ask them not to install a vp that was reman'd in CZ. The cz reman they installed in my truck under warranty lasted 7000 miles. I can't stress how important a fp gauge is. It can save you a lot of money and headaches down the road. With a comp I could pull the in tank pump to 0 without even getting into it.
fyi, i had the intank lp installed last fall by a local dealer. they told me that the new style pump was no longer covered under warrranty. obviously i wasnt happy at all. i called dc customer service and they proposed to pay all but $200 of the bill for the intank pump. the dealer wanted just over $900. so i agreed to have it done and pay the $200 deductable they called it. the dealer charged me sales tax on the deductable.
a short time after that i took my truck to another dealer and they were professional and helpful. they repalced my vp 44 right away for me. i was very happy with the service. BUT.... i have only been getting 14.5 mpg. i check the mileage by fillups and miles. i am not happy with that #. new filters and all. the only thing i have not been able to get to is the iat sensor. plan to check it this weekend.
going to have cummins install a fp gauge for me soon and keep an eye on that. i hope i figure out my mileage problem.
Hillbilly Delux
54
07-05-2009 07:15 AM
