Dead pedal. I think.. Help ...
I think I got the dead pedal problem, I was pulling out an old corn picker yesterday (scrap metal) that was sunk in the ground a foot, and I would go to gas it and get no power at all, then it would come on good and strong the next time. Then when leaving and pulled out on the hard road not towing anything it did it again, I mashed on it and it would barely move...
ah man don't say that, I just changed my fuel filter acouple amonths ago but I run alot of 2 stroke oil a quart a fill up and even a quart a half take too....I am at work and my truck is home I will have to check codes when I get home...almost afraid too....I ain't got the cash for fuel not alone a fuel pump....
I replaced my 44 about 6 months ago. I'm not positive but I remember 236 for the IP and 240 something for the lift pump.the intank dealership replacement aint much better than the original lift pump.put a good rail pump on it.
Well I checked my codes and this is what I had.....P0743, P1987, P1693, P1765.......I have my oil Pressure gauge unplugged on the dash so I think that is one...I have a manual gauge, Also had a TC lock up swithc so that might be one....But one of them said ECM PCM something...anyone have a clue......O and how do you clear them.....
P0743 Torque Converter Clutch Solenoid/Transmission Relay Circuits.
An open or shorted condition detected in the torque converter part throttle unlock solenoid control circuit (3 or 4-speed auto. trans. only).
P1687 No MIC BUS Message.
No CCD/J1850 messages received from the Mechanical Instrument Cluster (MIC) module.
P1693 DTC Detected in PCM/ECM or DTC Detected in ECM.
A Companion DTC was set in both the ECM and PCM.
Both the engine & truck computers know there's a trouble code...
P1765 Transmission 12 Volt Supply Relay Ctrl Circuit.
Current state of solenoid output port is different than expected (4-speed auto. trans. only).
Some codes reset after a number of normal condition starts, otherwise a scan tool will reset them.
600 Megawatts
03-26-2008 07:09 PM
