dead dead instrument cluster
I have a dead instrument cluster. I searched the post here and found what info I could. The truck runs and drives fine but no gauges at all. I pulled the cluster and cleaned and disconnected the battery for a half hour with key off. I found that my a/c clutch fuse under the hood keeps blowing don't know if that is part of the problem. otherwise all other fuses are fine I even pulled them all I even moved the relays around. where to go from here I don't know any ideas?
Not sure if this is similar to our trucks but when I lost the guages in my Tahoe it was a bad ignition switch.
A blowing fuse would be an indicator of something wrong in the electrical wiring though, I'd start there.
Disconnected batteries again this time instrument panel came to life for about 5 minutes. The speedometer went in and out first then rpm then everything else. showing 1693 1648 before gauges went dead again.
AggiePhil
03-16-2005 08:40 PM
signature600
17
02-21-2005 06:41 PM
AK RAM
05-04-2004 05:36 AM
