Dana 60 front axle blown? HELP!
Hello;
The truck in my signature may need a new front axle, or at least some work.
Here is what happened:
I had to park in a shallow ditch last night during my son's baseball practice. I engaged 4-wheel drive (4wd) before I went into the ditch because the ground was soft from rain.
Everything felt OK going into 4wd.
When it was time to leave, I had to cut my wheels hard to the right and go in reverse while in the ditch. As soon as I started moving there was a series of very loud pops/cracks and the front of the truck shook with them. I only moved about 4-5 feet when this happened as I stopped right away.
After that, I was not able to get 4wd to engage anymore! I almost had to get a tug to get out of the ditch.
Drove home just fine. When I got home I tested my 4wd on my gravel driveway. I do not think it is working because I did not get any of that wheel-hop while at full turn when I had 4wd engaged.
Also, I recently installed a 4x4 posi-lok system. I have used it a few times just to make sure I know how to engage it and it has always worked with no problems.
Any suggestions as to what is wrong?
How difficult is it to swap an axle from a newer truck? If I have to spend the money I want a setup from a 2000-2002 truck so I can do the big brake upgrade.
Thanks in advance for any and all replies.
--Matt
--Matt
That's what I'm going to have to do next. With Mother's day weekend and the kid's baseball game schedules I'm not likely to have time to do this for a week or 2 though...
At least we are a long time from snowy roads so I have some time to figure something out.
Ed;
You are exactly correct! I had time to wrench on it today. Turns out that I had not properly adjusted the posi-lok cable when I installed it; and the cable was not fully moving the collar inside the axle at the CAD all the way over. It was just not fully engaged.
After re-adjusting it all works just fine! I also saw no damage to anything under the CAD housing.
Thanks,
Matt
Thanks,
Matt
horselady
05-14-2011 08:40 PM
Ripper406
12-14-2004 07:45 PM
Commatoze
10-01-2003 01:07 PM
cumminsho2500
08-29-2003 09:56 PM
