Cummins 5.9 Isb
Cummins 5.9 Isb
I HAVE AN INTERMITTANT CHECK ENGINE LIGHT AND NO HARD CODES STORED. BATTERIES TEST GOOD. IT IS AN 02. 3OK ON IT. I HAVE ONLY HAD IT A SHORT TIME. CHECKED PIN FIT OF ALL I COULD ACCESS.
SEEMS TO BE ACCELERATOR RELATED. I CAN TAP THE PEDAL WHEN LIGHT IS ON AND THE LIGHT WILL USUALLY GO OUT.
IT GETS WORSE AS THE DAYTIME TEMP INCREASES. HAS MOST RECENTLY STARTED COMING ON AT IDLE. CAN TAP THE PEDAL AND LIGHT GOES OUT.
ANY HELP WOULD BE GREATLY APPRECIATED.
Try this:
https://www.dieseltruckresource.com/...n&onlynewfaq=1
If it is tied to the accelerator, that might be the ticket.
Welcome to the board, enjoy your stay.
phox
(oh, and before someone else mentions it, typing in all caps is akin to shouting in the internet world)
phox
I would bet that give it a little time and it will set a code. The codes are linked to the check engine light. You might try a scanner on it if you are reading the codes from the odometer. Go to any autozone and they will read them free.
turn on ignition and turn off do this three times and where your digital odometer is a code will show up would somebody please chime in and give the link to the page with all the codes and definitions. when cycling ignition do not bump starter just turn on and off three times wait and computer will self diagnose and code should show up where your odometer is good luck
