Cruise fuse location???
I was wondering where the fuse for the cruise control is located? also is the abs light linked with the air bag because its flashing on and off every so often so i think its my clock spring. one more thing can anyone give me step by step procedure to change the clock spring i pulled the steering wheel off today and saw the air bag it scared me so i put it back and came on her eto ask instead. thanks in advance
There is no Fuse for the Cruise control. Most likely the clock Spring. Here is a link that should help:
http://dodgeram.info/tsb/recalls/982.htm
There is a procedure listed there. I used it and it went easy. remember to disconnect the battery first. You just unplug the airbag.
hotdram
01-16-2005 11:45 PM
