Crank Trigger/Sensor replacement
Old 12-01-2009 | 12:12 PM
narleycharlie's Avatar
Needing to replace the crank sensor on my 99 2500 . Not my everyday truck , so I ve been putting it off not knowing what to expect . I ve got to do it in the parking lot where I have it parked and was worried about not getting it finished in time as to not leave it disassembled onernite .
Is this a big job ? I know the starter needs to be dropped , do I need a forklift for the desiel starter . Are any special tools required ? Any help would be useful , thanks , Charlie
Old 12-01-2009 | 12:29 PM
Copenhagenjunkie's Avatar
Here is what I got from Alldata, sorry no pic's.
REMOVAL
Crankshaft Position Sensor (CKP) Location
The CKP is located on the left/rear side of engine block near the starter motor.
Disconnect both negative battery cables at both batteries.
Remove starter motor. Refer to Starter.
Disconnect electrical connector at CKP.
Remove CKP mounting bolt and hold down bracket.
Pull CKP from engine block with a slight twisting action.
CKP Removal/Installation
Discard old CKP O-ring.
INSTALLATION
Install new O-ring to CKP Apply clean engine oil to O-ring.
Clean area around CKP mounting hole.
To prevent tearing O-ring, install CKP into engine block using a twisting action.
Position hold down bracket and install mounting bolt.
tighten bolt to 24 Nm (18 ft. lbs.) torque.
Install starter motor. Refer to Starter.
Connect both negative battery cables at both batteries.
Sensor To Vibration Damper Air Gap
Minimum 1.25 mm (.049 in)
Maximum 1.30 mm (.051 in)
Torque
Engine Speed Sensor Nuts/Bolts 24 N.m (18 ft. lbs.)
Old 12-01-2009 | 03:29 PM
BarryG's Avatar
Only thing I could add to the above is iirc the starter needs 12 point wrench or sockets to get the bolts out.
Old 12-01-2009 | 03:31 PM
Thanks Dude , sounds pretty simple and sraight forward .
Old 12-01-2009 | 05:42 PM
Wow that is a good point to bring to attention , and its probably all metric to boot . Thanks
Old 12-01-2009 | 06:04 PM
patdaly's Avatar
Yep, 10 MM.
I bought a cheap NAPA wrench and made an extension out of 1/2" rod for it to get better leverage. ( cut the open end part off, drilled the rod down 1-1/2", shoved the wrench in and flattened it )
Some 10 MM 3/8" drive 12 point sockets would be good to have as well.
Old 12-02-2009 | 03:30 PM
Junk Man's Avatar
Originally Posted by patdaly
Yep, 10 MM.
I used a small jack on the 10 MM wrench to get leverage when I changed contacts in my solenoid. Didn't need the jack the next month when I changed the CKP. Check your solenoid contacts while you have it off. It may save you a starter R&R.
Rimcrew
08-19-2012 02:04 PM
sjester
05-10-2007 06:03 PM
Gabe32
16
02-22-2007 07:37 PM
PaulDaisy
12-02-2006 01:36 PM
crabster
12-21-2002 12:35 PM
