Crack in top of fuel filter housing
I have a crack in the top of the fuel filter housing on my 98.5. Had it welded once and apparently the crack opened up and is leaking when under pressure. I'm trying to find a stock fuel filter housing. Anyone know where I might find one? I've looked on ebay but don't see one right now. Can't afford to spend the money on a new system.
http://cgi.ebay.com/ebaymotors/03-DO...item45f09a243e
http://cgi.ebay.com/2000-DODGE-CUMMI...item1e5a3527ba
Here is one on Ebay that came off of a 2000 dodge cummins for $45.00 plus shipping I don't know if this would fit on yours or not.
Does yours have the screw on plastic cap? I thought I seen one for yours on Ebay yesturday, but it must have ended. I do know they wanted $225.00 for it complete. It didn't have the screw on cap, it was all metal. I was looking for a fuel filter housing plastic cap for mine and remember seeing this one. They may relist it, you might want to check ebay often. IMO that is too much $ for the part. Good Luck!
Here it is!!
http://cgi.ebay.com/99-Dodge-Cummins...item53df6afc1f
Came off of a 1999
Description: Fuel filter canister removed from a 1999 Dodge Ram truck. Engine was 5.9 Cummins turbo diesel.
Excellent condition. Item number: 360230616095
Came off of a 1999
Here it is!!
Came off of a 1999
Came off of a 1999
He would be better off scraping together the money for an airdog or using an aftermarket filter like a Racor. Theres no need to use the factory filter. A filter is a filter. As a matter of fact, a few years ago there was a thread where someone had the same problem and replaced the factory filter with a generic type filter. I will see if I can find it.
willroach
07-08-2012 08:53 PM
BUFFALO_STEW
12-17-2009 02:42 PM
njforestfire
09-11-2008 12:19 PM
Dodgezilla
09-12-2005 10:31 PM
