coolent leak
Old 03-17-2007 | 12:11 PM
Buffman88's Avatar
coolent leak
i was filling up with diesel today and noticed a deacent sized pouddle of coolent. it is comming from the drivers side bottom corner of the radiator. is there some kind of sealer i can put on it or put in the coolent?
Old 03-17-2007 | 12:31 PM
SIXSLUG's Avatar
Isn't the drain **** on the lower drivers side?
Old 03-17-2007 | 01:24 PM
Buffman88's Avatar
you are right but it is not comming from the drain because the drain is completly dry
Old 03-18-2007 | 01:02 PM
fschiola's Avatar
I chased a leak down on my 1997 like this. I finally found it by shutting it down when warm and opening the hood and checking the head seal on the radiator on the drivers side. I found the seam leaking and it was running down to the drain area. I checked with a radiator shop as to resealing it, but they said that they didn't have good luck with that repair. I replaced the radiator in order to repair it.
etoy
04-22-2012 09:25 AM
91.5CTDBanks
08-26-2008 06:45 PM
DuaneWKKC
09-25-2005 04:02 PM
thumbs
10-01-2004 04:53 PM
thumbs
06-12-2003 12:18 PM
Quick Reply: coolent leak
