Confused
Confused
I have a '02 2nd. gen W/ 138,00 miles, the trans. come out of a corner and stuck in first gear until RPM reached about 3200 and made a hard shift...... It was the last time that it would go into first gear, now I must start out in second gear regardless if I use the column selector or in drive. If I start out in drive it starts in third and either way 3 to 4 to o.d. and o.d. lock works flawless- A transmission shop told me that the code told them that the transmission wasn't communicating ? Fluid is fine and not burned and full to the line --- ANY IDEAS ????
They didn't tell me the code and when the pan was removed I was told that a lot of clutch pack material was present and a lot of metal shavings on the magnet but I got the truck used and have no idea if it had ever had the fluid and filter changed..
Check your grounds and take a look at the fluid.
Sounds like a fluid change is the least of your troubles. THe ground issue on the other hand is not that uncommon when the auto trans start acting up.
The Boss Hog
12-20-2002 05:03 PM
