Common Electrical problems? (not dimming headlights)
So, recently I lost 5th gear and forgot about the 5th gear nut issue. Currently I'm having a few electrical problems and cannot think of an obvious causes. Without going into too much depth of details I'll just list the components and see if anyone's dealt with or knows of these problems.
1. Right Blinker and Brakelight don't work (bulb was replaced) and no fuses are blown.
2. Windshield wipers intermittently don't work unless set to the fastest mode.
3. There's either a considerable draw off the alternator (short somewhere) or the alternator is dying because at idle the voltage gauge reads low.
Thanks for any insight!
i dont ahve any of that but now my heasdlights wont switch from high to low when i do they shutt off like you just turned the switch off but i will keep switching back and forth and finally it will comeback on only goes of from high to low sort of wierd so now i just drive with my low beams everywhere
Journier
21
11-26-2010 08:41 PM
HOBrian
09-14-2007 09:00 AM
