cold weather problem
Temps were below 0* for several nights last week. Truck sits outside at work with no elec for the block heater.
Truck started/idled fine, ran about 5-10 minutes while I cleaned the windows off. Drove off and the truck began missing/stuttering. No power and wouldn't rev more than @1500 rpm. After about 5 miles, it cleared up and ran normally. This is the second time it happened during very cold weather, first time I thought maybe the fuel was starting to gel(even though I've always added anti-gel chemicals), but now I don't believe that's the issue. The only addition to the truck since last winter(and I had no problems last year) is the van Aaken box. Could the cold be affecting it?
Anyone had a similar issue?
I had a similiar issue when my VP started acting up, check your codes. It could be a bunch of things though. Water in the fuel from sitting, air in the lines possibly. Even though you put an additive in there, they only protect down to a certain temperature, from gelling...that's a while to sit with no cord plugged in...
Fuel is gelling. Had it has happened to mine too many times. Our fuel these days is crap. If it has much soy/animal fat in it you need 2-4 times the recommended anti-gel. I use powerservice liberally and only Cenex fuel, Roadmaster #2 or Wintermaster when its -10 F or colder. I add 2-3 times the recommended amount of anti-gel to every tank in the winter. I also change my fuel filter every 5K in the winter.
Every time mine has gelled, it acts just as you described.
FWIW
Matt
FWIW
Matt
joel
01-22-2005 08:59 PM
